Help! Rear wheel recomendations please
Hixyhicks
154
10
56
After going to to bike shops in stourbridge this morning,and having a nite-mare trying to replace a f ing spoke i have decided just to buy a new back wheel.The wheel on it at the moment is
Alex HRD 26"", alloy double wall, pinned, 32h
Can you please recommend a new one.I have an 8 speed cassette on at the moment but im going to shorten it to a five speed
Thanks in advance
Mick
3,994
Rim or disc brake?
You can use any 26" wheel that has a cassette spline as long as it's for whatever brake type you have. Disc brakes need the 6 mounting holes in the hub and rim brakes need the flat sides to grip on.
You can find loads of used and new wheels on Ebay. If it's important to you, choose one that looks similar to your old one so that it matches the front wheel. Personally, that wouldn't bother me.
Hixyhicks
154
10
56
The wheel has a cassette on it,i mean it slides on.Im looking for heavy duty wheel if possible .
8,843
Why buy a new wheel when a spoke is relatively easy to replace ?
Just needs a bit of patience.
Hixyhicks
154
10
56
I didnt realise there were so any types of spokes i believe its 2mm then do i just measure it?
Hixyhicks
154
10
56
The spoke measures 10" or 225 mm and it came of the side of the hub the cassette is on.The thing is its looks like the threaded end which is only about 5 mm has broken there.
8,843
Remove a good spoke and measure it from thread end to inside of the J.
Use 14g /2mm spokes, I buy mine from ' spokes from ryan' and use sapim strongs.
Related Articles
