March 16, 20215 yr Hi there I'm new to this forum so please bear with me so my question is what motor should I get for my bike (rear hub or front wheel motor) also what conversion kit should I buy? I was thinking 36v 250w but I'm just a noob, that's my bike could someone help me what would be a better option (rear or front wheel) I also want a twist throttle. Thanks Abzy
April 19, 20224 yr Hi there I'm new to this forum so please bear with me so my question is what motor should I get for my bike (rear hub or front wheel motor) also what conversion kit should I buy? I was thinking 36v 250w but I'm just a noob, that's my bike could someone help me what would be a better option (rear or front wheel) I also want a twist throttle. Thanks Abzy HI, Rear wheels are better for the road but harder to install Front wheels can make you spin with high power motors, the bike will be less stable but it is easy to install
April 19, 20224 yr Front hub depends on the power put through it, I have a nice Bafang G370 on the front which nicely tows a heavy laden trailer with only 4 - 6a of power. I have no need really for much more current and one will only get any serious wheel spin if one lumps 15 - 20a from the off. Edited April 20, 20224 yr by Nealh
April 20, 20224 yr Tandem is different weight distribution; but with our front wheel hub we've never had significant front wheel spin, and have fairly often had rear wheel spin from pedal power which the front motor has pulled us out of. (Typically on slight uphill on slippy damp grass bridleways with unsuitable Marathon Plus tyres). There's a lot to be said for 2 wheel drive.
April 20, 20224 yr I think losing grip on the front has been massively over-stated by many but I'm sure a light rider going up a steep hill with a powerful front hub motor may well lose grip especially on surfaces with poor grip for sure but for legal wattage ebikes I personally don't think its an issue. On some surfaces like sand where you have two powered wheels, rear powered by you and front powered by the motor grip can be improved. You can do a test though to see how good it will be on your bike before you fit a front hub motor. Go up a steep hill as fast as you can for a short spurt and then apply the front brake hard to see how much traction you have and if you skid. Ideally a situation where you have a nice flat run up to the hill to build up speed and then can start the hill at some speed as soon as you are going up the steep bit apply the front brake on its own as hard as possible. If you skid immediately then perhaps the weight balance on the bike or your lack of weight etc means it would be less than ideal to fit a front hub motor. I've also seen it written that for a e-mountain bike it is better to have a rear hub motor than a front hub motor and that maybe good advice overall but with a hardtail mountain bike where the rear of the mountain bike gets a lot of abuse and doesn't have any suspension to cushion the impact, rear hub motors especially direct drive can break a lot of spokes and have issues. So still seems less than ideal. If I wanted to configure a e-mountain bike and couldn't have a mid-drive motor I would probably have a smallish light geared hub motor on the front suspension forks. That goes against a lot of advice I'm sure but then I would be using the front hub motor to get me up the hill on the road or normal tracks before I then I would do the downhill technical course and could see that working quite well. The advantages I see for front wheel drive; 1. Often on many bikes even aluminium frame bikes the front forks are steel so better for mounting a hub motor. 2. For heavy riders like me I get more punctures at the rear so prefer to have the motor at the front because its more difficult to remove to change tubes. 3. Again I'm more likely to be working on the rear wheel with regard cassettes, spoke replacements, bearings adjustment etc so prefer to have a easy to remove rear wheel. 4. Many cheaper rear hub motors have freewheel fittings and I wouldn't want that I want to use a stronger higher quality freehub on the rear wheel. You could argue that freehub rear motors aren't that much more expensive but then you have the extra complexity of a freehub ratchet system and the motor itself built into the same hub motor. 5. Not compromising the drivetrain options means I can have the exact gearing I want. Freewheels typically have a maximum range of about 14-34T which is very limiting for both high and low gearing. 6. Not much give in a hub motor rear wheel if fitted with a larger direct drive hub motor. They have short spokes and do not flex much they can feel a bit harsh unless you are using very thick tyres. I prefer the more springy wheel on the rear as aluminium frames are more harsh and prefer the harsher front hub motor on the front where the steel forks have more give. It feels the better combination. 7. Less of the weight of the rider is at the front which is why grip is slightly reduced but this means less load on the bearings and spokes which can make the motor last longer before attention. 8. If you wanted to return the bike to a conventional bike for perhaps a long distance ride or while you were servicing the hub motor you only have to swop back to your normal front wheel and take off the battery and most of the weight is gone. 9. Tyre wear seems to even out a lot more so you don't have to swop tyres as much between front and back to get even tyre wear. 10. I quite like the slightly heavier steering at the front for some reason, feels a bit more like a motor bike when you have a front direct drive motor hub. 11. Easier to repair punctures when you don't have all the gears in the way as well as the cables when removing the wheel to change the tube. In fact I would say it can even it out a bit. 12. Regen braking works better on the front in my opinion as remember when you are going downhill the weight now goes far more to the front of the bike, its the only time really when there is more weight on the front wheel so adds to traction. If you have the bike setup so that the rear brake lever activates regen braking then the first light pull causes the ebike to brake using the front hub motor which recovers energy but if you pull harder it then operates the rear physical brake where most of the riders weight is so the best grip and the best braking performance. If you are really in a situation where you have to brake even harder then obviously you can pull the front physical brake lever as well but I feel all you need is one lever braking 99% of the time and 95% of the time you don't need to activate physical brakes at all just regen braking which means longer range and zero wear to brake pads. It's always best to share braking between both wheels it reduces brake pad wear and tyre wear and its good for the structure of the frame and forks. You could of course argue to have regen braking on the rear and front wheel physical braking but to me that doesn't work quite as well.
April 20, 20224 yr Nicely summed up BB. Only #12 might be a sticking point as one needs the DD drive motors for regen. Edited April 20, 20224 yr by Nealh
April 20, 20224 yr My bpm with 20a at the front is a beast, heavy, torque steering affect and wheel spin at time seven on flat terrain and after a while tiring, I have used it in a 700c town bike and then on a mtb for off road. Compare the small light G370 and it is quite the opposite and a joy to use, the main difference is the internal motor gearing the latter so much more usable if power isn't wanted.
April 20, 20224 yr For anyone wanting to make there own kit up, it is quite easy. Peeps only need to ask for advice and the correct components to buy and any fitting should go quite swimmingly when making up a suitable front motor kit. If one wants just light to medium assist or a light weight build option then a good 250w lightweight geared hub given even a menial 3 - 10a of power is plenty for a 13/14st rider on relatively flat terrain with some small hills , if one wants power then opt for heavier type hub or DD hub. Though for any front hub a steel fork set up is most recommended, for the light weight hub one doesn't need any torque arms in steel fork.
April 20, 20224 yr Nicely summed up BB. Only #12 might be a sticking point as one needs the DD drive motors for regen. The best regen motors seem to be geared hubs weirdly but you have to disable the freewheel type clutch plate. I think without the freewheel mechanism they become even more grim cycling them without power to the point where I think you have to operate a trickle current type situation to restore the freewheel effect. I'm not a good enough engineer to understand why this isn't a common commercial product or even why direct drive hub motors can't also be fitted with a freewheeling clutch plate arrangement. Regen often bypasses BMS over-charge protection and I guess if geared hubs are better at it there is more risk of over-charging the battery and leading to explosion.
April 20, 20224 yr That's why geared hubs don't use regen, pointless making them with a freewheel if one has to disable/mod them for regen.
