I recently fitted a Swytch kit to my Brompton, its OK for short commuting type trips, but in the area where I live (Cardiff) the roads are so bad the ride is a bit harsh to be fun for long. The extra stiffness of the front wheel cannot help.
I have an old style Mountain bike, its a 26” wheel custom Titanium Rock Lobster, with mostly Shimano Deore XT stuff, Hope mini Hydraulics and Marzocchi front shocks. The ride is a lot more comfortable on the roads than the Brompton. I thought to do an ebike conversion on it and have a Bafang 250W rear hub motor kit due to arrive in a couple of days.
I can see that the PAS is not straightforward on the Hollowtech cranks, I have ordered one of the PAS disks with the large hole, so I hope to avoid having to replace the cranks.
Now to a question;
The gears are Shimano 9 speed cassette, the Bafang rear hub motor needs a 6/7 speed freewheel, and although its no great expense to just fit a 7 speed freewheel and a new 7 speed shifter, it would be useful if I could keep with the Shimano 9 speed setup.
A 9 speed freewheel, with one cog removed, should be about the same height as a 7 speed, so it might fit, the rear drop out is 135mm.
Are there any 9 speed freewheels out there that you could slim down in this way ?
Now to a question;
