Hi, just wondering, today I had to replace my rear brake pads, they were down to the metal. Only had the bike just over a month is that normal?
Normal if you go fast and brake a lot I suppose.Hi, just wondering, today I had to replace my rear brake pads, they were down to the metal. Only had the bike just over a month is that normal?
Me too and changed mine at 900+ miles.Not sure what type of pads the were, just came with the bike. I'm quite a heavy chap at 100 kg and all my rides are up in the mountains, I guess I'll just have to change them regularly.
I had the same problem when I first started ebiking, never touched the front brake atall for the same reasons you say, untill I learned off this forum about the front generally being the main brake when safe to do so. It takes a bit of getting used to but really enhances your braking when using the front first.Hi again, my technique must be way out if you only use rear brake 10% of the time, I probably use it 80% of the time. Scared of losing grip on the front wheel or worse going head first over the handlebars. I'll have to have a re-think......cheers
As you've probably now gathered, when you brake a bicycle the vast majority of the weight transfers to the front wheel.Thanks for all the advice guys, just Googled MTB braking techniques and it does look as if i'm too reliant on my rear brake. I will see if my new pads are any better and also adjust the way I brake. ......cheers
