''They are the same bike, the Dover isn't a deluxe version. If it was it would have the Alfine 8 speed hub gear, but it hasn't, both bikes have exactly the same Nexus hub gear and their other specifications are the same''
Not quite true, I have seen a review where the Raleigh versions of the bikes are classed as the deluxe versions in Germany and as such attract a higher price.
The Alfine 8 and the Nexus 8 now have the same internals
http://bike.shimano.com/publish/content/global_cycle/en/us/index/tech_support/tech_tips.download.-Par50lparsys-0016-downloadFile.html/09) Differences Between Hubs.pdf
The Alfine 11 is now the upgrade
The forks are supposed to be Raleigh units (though i can't see any difference)
The saddle is certainly superior, with quick release clamp.
The crank arms are a better finish
The Handle bar stem is a very nice brushed aluminium.
The handle bars are aluminium, swept back units
The lights were superior, now the same on the 'new' Agattu
The tyres are Schwalbe, Continental on the Agattu. (same crappy Woods/Dunlop tubes though)
The paint job on the Agattu is not in the same street as the Dover
The electronics are supposed to be 'tweaked' by Raleigh for better performance (though i don't see how)
The manual and paperwork are better and come in a 'nice' plastic folder
You have the whole Raleigh network behind you, (50cycles are the sole importers of the Agattu)
The assistance ratios were as stated, the higher assistance of 2 is with the 18ah battery, this is not a Panasonic unit and i suppose is not yet tested, though its covered by the same 2 year warranty so should be no problem.
I suppose one thing to consider is that the 18ah battery is £121.60 more the 10ah when it comes to replacement
One last thing, 50cycles price is set, no haggling. I have seen the Dover at cycle shops on the internet for £1500.
Make your own mind up if you think they are the same bike.
I used Lexus and Toyota as an example, which was probably wrong it should have been Skoda/Seat against VW, almost the same cars just styling. but check out the VW prices
