Quick 'Battery Voltage' Question
Ebiker555
9
Hi guys,
My new ebike battery says on it that it has a 30v Output & 42v Input.
Could some of the wiser heads on here clarify if this is a 30v or 42v battery in the sense of how you are supposed to determine battery voltage?
Reason being I paid for a 36v battery & don't know if they've supplied me with a battery of 6v less or or 6v more?
Appreciate your advice....
8,781
Likely label is wrongly marked and should read 36v out put (nominal) and is a 42v max charge rate.
Measure the battery out put with a meter.
A 36v battery is it's nominal voltage which is about 50%, fully charged 100% it is 42v.
Min discharge is 30v but generally it is detrimental to keep going that low.
8,781
Do the math and it all adds up correctly you have a 36v nominal battery.
36v x 15.6ah = 561.6wh just as it states on the label.
Deleted member 25121
Thanks for your reply. Here is the label on the battery. Would you class it as a 30v or 42v battery ?
Chinese quality at its finest eh. It's almost certainly a 36V battery, try measuring the voltage with a DVM.
