Questions about a Bafang QSWXK or Cute Q-100SX front hub build
Hi all and happy new year,
I decided to go forward with a bafang QSWXK 36V/250W front hub, 26" wheel build. I'll be ordering stuff from BMSbattery / ECITYPOWER or similar and I have a few technical and non-technical questions. Here goes:
1) regarding disc brakes: I've read that the QSWXK has to be laced with all spokes heads-out/butts-in on the disc brake side or else the caliper will interfere with the spokes. I suppose this is true for 160mm rotors, but is it also true for 185mm or 203mm rotors? For those of you with personal experience, is it laterally safe and stable to build a wheel all heads-out?
2) I'll be ordering the motor, sensorless controller, thumb throttle, charger and 36V/10Ah battery, say from the BMSbattery site. Does anybody know if these come with all necessary connectors? What type of extra connectors will I need?
3) are 13g spokes really necessary? I mean a steel fork can absorb some vibrations and 13g's will make the wheel stronger, but man are they rigid! Won't some quality 14g DT Swiss spokes cut it?
4) also, are torque arms necessary? If so, could they be substituted with, say, non-turn washers or something?
5) and a non-technical question: How probable would you think it is that such a large package is stopped/detained at the customs office? Am I looking at some 30% surcharge if it happens? The package will probably be sent with DHL (I would prefer to use EMS instead, but they charge literally double the price)
So, that's all for now. Any help will be greatly appreciated.
