It certainly has a chance to work better!I need another one.
My speaker is only 150W. It probably has peak power but not much. When looking at power drawing, it's mostly around 30-50W continuous. So really not popping that much power.
I need something else. Would this work AND be reliable?
5000W Peak Power Inverter DC 12/24V 48/60V to AC 110/220V Sine Wave Converter | eBay
Peak Power : 5000W. 1x Electromoblie Battery Cable (for 48V or 60V). 48V&60V Auto-Adaptive. - The inverter can convertDC12/24V 48V/60V to AC 110V/220V, and one inverter can be compatible for both 12V&24V or 48V&60V.www.ebay.co.uk
It's not pure sine wave but maybe it doesn't need for speakers?
But its not the speakers that you need to worry about, its the electronics that drive the speakers that may have a hum at the frequency of the "not sine wave" mains you produce!
Usually, if you put an Oscilloscope on the output, its more of a square wave.
A square wave consists of a fundamental sine wave (of the same frequency as the square wave) and odd harmonics of the fundamental. The amplitude of the harmonics is equal to 1/N where N is the harmonic (1, 3, 5, 7…).
Square Waves And DC Content: Deconstructing Complex Waveforms - ProSoundWeb
Illustrating the harmonic structure (content and phase relationship) of a signal
www.prosoundweb.com
How much power is needed to drive the electronics is greater than the power needed to drive the speakers. Speakers, especially good ones, need a lot of power to make noises. VERY inefficient! This "lost" power is generally lost as heat!
Here you can see the difference between a modified sine wave (the sort of output many inverters make in RED, and a true sine wave in BLUE.
A 1:1 isolation transformer on the inverter output will also help to reduce noise and to shape the sine wave better....
If you have any further questions, please just ask.
Andy
