Hi, Haven't bothered updating my Purion with the emtb mode. I'm happy with current modes eco, tour, sport and turbo. Would it be worth updating software or leave alone?
Be careful about emtb mode. At present if you go from tour to sport you get a welcome increase in assist, without any increased effort. If you go from tour to emtb you will feel no difference until you put more torque on the cranks.Hi, Haven't bothered updating my Purion with the emtb mode. I'm happy with current modes eco, tour, sport and turbo. Would it be worth updating software or leave alone?
Yes I read this, a number of people seem to have asked for update to be removed. Stick with what I have, full control of power option myself. ThanksBe careful about emtb mode. At present if you go from tour to sport you get a welcome increase in assist, without any increased effort. If you go from tour to emtb you will feel no difference until you put more torque on the cranks.
Emtb is supposed to cover from tour to turbo automatically but it is torque related and even pedalling hard in emtb I still had a boost when going up to turbo. So obviously I couldn’t pedal hard enough to engage turbo. I reverted back to sport after six months of emtb.
On the contrary, I think that emtb looses out on hilly terrain. For the reasons I stated above, if you ate pedalling in tour mode up hill and want more assistance without more effort then you will not get it with emtb. Flicking from tour to emtb makes no difference whatsoever unless you apply more torque to the pedals.eMTB comes into its own on hilly terrain where it acts a bit like an automatic gearbox on a car and once you get used to it it's great.
If you ride mostly on the flat you're probably best not to update.
As I said, eMTB comes into its own on hilly terrain ie terrain with ups and downs.Emtb becomes more useful on steep switchback uphills in MTB parks, of which I have done a lot, as it means that you don’t have to keep changing modes but this amounts to a small percentage of my riding.
But obviously on a very limited type of hilly terrain. You seem to be suggesting that emtb is better on all hills. It does indeed “come into its own” on hills were you are constantly switching modes but “it’s own” is far inferior to sport mode. It is also of no use at all on the downs.As I said, eMTB comes into its own on hilly terrain ie terrain with ups and downs.
As I said, eMTB comes into its own on terrain with ups and downs, which tends to be the case in hilly areas.But obviously on a very limited type of hilly terrain. You seem to be suggesting that emtb is better on all hills. It does indeed “come into its own” on hills were you are constantly switching modes but “it’s own” is far inferior to sport mode. It is also of no use at all on the downs.
You’re beginning to repeat yourself but it is still wrong. May I ask if you have a Bosch motor with a Purion display?As I said, eMTB comes into its own on terrain with ups and downs, which tends to be the case in hilly areas.
You may.May I ask if you have a Bosch motor with a Purion display?
It sounds as though you have a thorough understanding of the correct use of cadence, gearing and torque, which of course is the way to get optimum usage from the mode.As I said, eMTB comes into its own on terrain with ups and downs, which tends to be the case in hilly areas.
I found it took a few long rides to get used to the eMTB mode but once I had the feeling for it I liked it. I find it to be more sensitive to torque than cadence and its nice to be able to push a little harder on the pedals, just for a couple of rotations, in order to get a spurt out of the motor. Its similar to the way you can dab the accelerator on some modern automatic gearbox cars to get it to change down.It sounds as though you have a thorough understanding of the correct use of cadence and gearing, which of course is the way to get optimum usage from the mode.
I agree that it is pointless arguing about the subject but no one on this thread has yet argued only expressed their opinions which you have participated in.Some people like it and others don't but it's pointless trying to argue about it, as some seem to want to do. It's like trying to argue about whether marmalade is better than Marmite.
Can you explain what effect cadence and gearing has on emtb mode?It sounds as though you have a thorough understanding of the correct use of cadence and gearing, which of course is the way to get optimum usage from the mode.
In that case, why have you repeatedly questioned my opinion?I agree that it is pointless arguing about the subject but no one on this thread has yet argued only expressed their opinions which you have participated in.
I can, and have now edited my previous post to include torque.Can you explain what effect cadence and gearing has on emtb mode?
