I have been free of punctures for two years, since changing to Schwalbe Marathon tyres. Last Wednesday, I was out on NC1, when I had a twig attach itself to my rear tyre. I noticed it was attached by a thorn. I pulled it off, and could hear no escape of air. I biked on for a couple of miles, and stopped at a cafe for a cuppa. Halfway home, i stopped for a vape, I checked the tyre and noticed had lost some pressure.
I decided to ride home. After a hundred yards, I stopped again, as the tyre was too flat to ride. I decided to pump it up to get home. It would not inflate, so i assumed there was a big hole in the tube. I decided to fit my spare tube. Wheel out, tyre off. Needed to put a little air in the spare tube to fit it. I could not get any air into it.
I found a long strong thorn had pierced the tyre. I tried to push it back through, but it broke off flush with the inside of the tyre. Luckily I was riding with my buddy Nigel, who had a mini pump. Fitted the tube, and the mini pump worked very well, getting the tyre up to normal pressure. We rode home, and I mended the punctured tube, leaving it well inflated overnight. It stayed up so I put it back in my pannier.
Today I went to Halfords to buy a new pump connector., because I discovered a hole in mine, which is why the pump failed. They had a connector at £2.99. Beside it on the display was a standard bike pump, WITH CONNECTOR, at....,......£2,99! I bought the pump, but unfortunately, the new pump does not fit my frame, so I will just be using the connector.
