How did you get on with the tyres, GaRRy ?
Sorry not replied sooner but not gone totally to plan yet. however this is is how its gone so far.
Last Saturday did this route on the xtrem
15.91km mountain bike on 23/02/2013 in Tamworth, EN | MapMyRide
Route is a mixture of tarmac and canal tow path. So nothing to demanding but certainly with a bit of mud in places.
Then on the Sunday I did the same route again on the Cross but unfortunately for some reason it only recorded half the route.
8.61km mountain bike on 24/02/2013 in Tamworth, EN | MapMyRide
Note for both rides I did ride at a good steady pace neither trying to put in the fastest time possible or just cruising along at a leisurely pace.
So yesterday to get a full reading for route I went to use Cross again only to find it has a puncture in rear tyre which I guess proves that the marathon plus MTB/Giant thorn proof tyres win on that count
So unfortunately dont have a full set of stats to compare. However did discover a few things. Firstly from the route distance recorded twice it is obvious that the cross with continental contacts is definitely a bit quicker (basically because it is easier to get it up to cycle above the assist speed cut out (mix of tyres and gearing probably reason for this).
But the most important bit is on the mud/loose gravel I defiantly felt more secure under braking / turning on the MP MTB. However on the road/hard stuff the opposite was the case with the MTB tyres being more skittish and more include to skip about on groves and joins in the Tarmac. Im also sure this would be worse in the wet.
As for noise from tyres there was not really that much difference.
So as to whether its better to fit a mix use bike out with MTB or dual use tyres it would appear to be down to how much time you are expecting to be spending off road and even then how much of it is likely to be loose surface/mud.
One final thing to note was the battery level on the extreme was defiantly less at the end than for the cross but this could be down to slight difference in battery performance. (I did intend yesterday to use the battery from extreme to check this out).
Any other questions please feel free to ask and I will try and answer.
