Problems with power on Freego Eagle
Mike63
809
64
Hi...I've been running 3 year old freego for last 2 months with no problems.
A few days ago it was out in the rain for half an hour and then it wouldn't start.
...plenty of power in the battery but none getting through to the bike.
.....anyone any idea what I could look at ?
....appreciate any advice.....Mike
Have you got the manifold on the headstock and the connectors between it anf the things on the handlebars? If so, unplug the brakes, otherwise open the controller compartment under the battery and disconnect the brakes there. They're the connectors with two wires.
Mike63
809
64
[QUOTEHave you got the manifold on the headstock][/QUOTE]
thanks d8veh....I'm afraid you lost me at "have you got" :)
...any chance you could explain it to a dummy like me ?
....'preciate it......
....cheers....Mike
PS. forgot to say that all lights on handlebar console are working ok.
There's wires that run from the throttle, display and the brakes. Do they each go through an in-line connector to a little block that only has one wire coming out?
Mike63
809
64
Hi d8veh.....I have unscrewed the tiny blocks fastened to the underside of the brakes, I've removed the block from the handlebar stem and removed the front, all seems to be in order here, no broken wires....what can I do ?
thanks....Mike
Mike63
809
64
...forgot to say that all lights on handlebar console are working ok
...and front headlight works fine.
cheers...Mike
Just unplug the brake connector and leave them disconnected while you try it.
Mike63
809
64
...are you referring to the tiny block connectors on the underside of the brake levers ?....if so, I've done that...doesn't work.
cheers....Mike
Isn't there another connector between the brake and the manifold?
Mike63
809
64
No sorry......just one from the console on one side and one from the throttle on the other.
Mike63
809
64
Hi again....I'm away for a couple of days Tuesday next, if you think of anything that might help I'd appreciate it.
....many thanks....Mike
dmsims
67
14
South Devon
On that age of Freego there should be an 8 way rectangular connector between the chainring and the rear wheel bound in tie wraps and rubber (follow the cable from the controller)
The pins can get corroded and/or pushed back examine it carefully when apart
I replaced mine with the newer round small connector that they now use - deep joy soldering 16 connections :)
New connector:
Mike63
809
64
...thanks for that dmsims... looks good...I will certainly check it out.
cheers....Mike
