Got the 350w version with brakes and throttle and Large display(VLCD-5). It was an easy fit, couple of hours at most including my many tea breaks, Really nice motor looks a lot better finished than the bafang and very stealthy. Soldered an XT90 on and connected the battery, everything lit up as expected, i was careful to just let it do its own thing for a few seconds, then came the problem. I can't get into the setup mode to set the wheel size, change KPH to MPH etc. I followed instructions which are press and hold "start" and "i" for 3 seconds then you use "i" to move through the menu except it doesn't happen. Its not straight forward like the Bafang where you can see instantly when you are in the right menu. With the Tongsheng nothing changes until you "i" it past the end of the usual menu items then the code for wheel size appears, or in my case doesn't appear.
I have taken it out on the road with the default settings and everything seems fine except its not reading correctly as expected, infact my top speed was 99.9 KPH wow i must be fitter than i thought LoL. and a mile and a half came out as 58 kilometers.
So i think two things are wrong, the display is faulty because i cant get into setup and the magnet wheel sensor is kaput because of the outrageous readings.
Have contacted PWSPower who was the vendor and they sent the VLCD-5 manual which i already had and said if i can't sort it, send it back at my own expense and they will repair it, which i suppose is good for Chinese vendors.
But before i return it i wondered if any of the Tongsheng owners on this site had any ideas, because its going to take a couple of months to get it back and fixed, and i am now worried that it might not be the display although logic tells me it must be.
