Hi all.
The gear change cable on my Pro Connect is now at the extent of the adjustment available at the shifter end (the screw adjuster is right out). In gear 4 the two yellow lines on the hub do not quite match up but there's no further adjustment available to get them to match up exactly - especially if the cable 'stretches' any more. Currently I'm not having any gear/gear change problems but maybe it only a matter of time before I do (I needed to make an adjustment soon after taking delivery a couple of months ago when I had an odd 'crunch' in the drive train).
I assume the only other adjustment is at the hub end - the inner cable fixing bolt unit? Is this right and is it an easy 'operation'? I've got a copy of the shimano service instructions (Thanks again to this valuable forum for the links). However, I'd like advice on the difficulty of doing such a task as a reasonable competent 'novice' but my only previous experience of hub gears is the good old Sturm-Archer 3 speed!
I've read various posts on the Pedelecs site about the hub cassette etc. re changing sprockets/removing rear wheel etc. but would like to get a grip on the level of difficulty in 'fiddling' with the inner cable fixing bolt unit if that's what I need to do.
Hope you can help.
Mike
Hope you can help.
Mike
