What are the regulations re: lights? Escooters being lit like lighthouses is my preference, because I never see or hear these damned stealth ninja death machines approaching, while I'm cycling or when disguised as a pedestrian, until after they've nearly killed me.
E-scooters will have to be fitted with front and rear lights and two independent braking systems so that if one fails the other will still work.
They will not be required to have indicators but if they do, they must be amber.
This one has plenty of lights on it and should suit you.What are the regulations re: lights? Escooters being lit like lighthouses is my preference, because I never see or hear these damned stealth ninja death missiles approaching, while I'm cycling or when disguised as a pedestrian, until after they've nearly killed me.
Thanks, so not "all public places".Not for use on pavements, no seat, not for carrying goods according to gov. ie
I found one exactly like that dumped on the side of the road. I plan to live stream broadcast it's long grisly torture and dismemberment, until all escooters surrender:This one has plenty of lights on it and should suit you.
Dualtron X Limited 60Ah
Experience power with the Dualtron X Limited 60Ah equipped with a 60 Ah battery, this electric scooter boasts a top speed of 75 mph and offers a range of 100 miles.dualtron.uk
The Republic of Ireland, the South. As an EU member they are clearly following the rest of the EU.Which part of Ireland, Northern or the rest of Ireland?
All e-mopeds are classed as Mechanically Propelled Vehicles (MPVs)*, like a car or motorbike, and therefore the same penalty points and related fines apply.
That would cause every single ebiker and most scooters to have to pay the fine every time they used their vehicle. What does it mean? How will they measure it?Exceeding the maximum continuous rated power of the electric motor, or combination of electric motors €50,
I doubt they will measure it. Like us, they will go by what the makers label and seller says it is.That would cause every single ebiker and most scooters to have to pay the fine every time they used their vehicle. What does it mean? How will they measure it?
It says exceeding the rated power, not using a motor that has a higher rated power than is allowed!I doubt they will measure it. Like us, they will go by what the makers label and seller says it is.
