6,733
they cant even work out if is going to rain or not in 24hrs as said rain here at 4pm and pure sunshine and 2kw from the panels could get more but council has not bothered to clean them in 9 years so 30% down :rolleyes:
17,441
No it doesn't. A rise in temperature makes less rainfall because the moisture stays in the air. Didn't you wonder why it doesn't rain in the desert?
How much vapour goes into the clouds must eventually come out as rain (or vapour) or else where would that water go?
Deleted member 16246
I agree about the catastrophising of the BBC and others (two years to save the planet etc), but there is something missing in your analysis.
Yes - warm air holds onto its heavier water vapour load, but when that warm air is raised up by being heated, or by being forced up by moving over higher terrain, its pressure falls, the air is cooled at altitude and the water vapour condenses. You can see this happen on the top of an aircraft wing too when the flaps create extra low pressure above the wing.
If the content of the water vapour in a raised up air mass is particularly high, the rainfall will be very much heavier. You will no doubt recall the cataclysmic thunder storms of hot summer days as an example. Those are usually caused by moist clear air being raised to higher altitude when they move over hot ground.
The hurricane seasons in the USA are driven by hot, wet air moving inland and so are the Asian monsoons.
57282
4,236
  • Disagree
6,733
and cloud seeding does work as been trying it since 1950s chem trails are to stop it raining like the met office none of them have a clue what there doing and dont care as long as making money out of it.
if all this green crap was any good why did the council leave me with a faulty inverter out of service life that i had to fight for to get replaced and not bothered to clean the panels since 2015.
the service manual says they to be cleaned every 6 months or will loose 30% if not cleaned so they dont give a crap and have put in a complaint as why there not cleaned as in there interest as they get the money from them. from there corporation subsidised scam because as long as the counter on the wall says it is generating power it does not matter if the inverter works or not and proven this and if anyone's house burns down because there inverters are out of service life and the council has been told yet does nothing about it.
The bad weather had already been forecast.
"BBC Weather meteorologist Matt Taylor also noted the severe weather event had already been forecast. "Ahead of the event, computer models (that don't factor in potential cloud seeding effects) were already predicting well over a year's worth of rain to fall in around 24 hours," he said.
"The impacts were much wider than I would expect from cloud-seeding alone too - severe flooding impacting large areas from Bahrain to Oman."
Cloud seeding missions in Emirati territory are run by the National Center of Meteorology (NCM), a government task force."
6,733
ted better not watch the bbc. :p
4,800
1,258
4,236
BBC: False claims by conspiracy theorists that cloud seeding caused the floods.
In the BBC article it says "Cloud seeding was done on Sunday and Monday, but not on Tuesday when the flooding occured", so conspiracy theorists are wrong. You've got to love these fact checkers.
From Bloomberg:
"The Gulf state’s National Center of Meteorology dispatched seeding planes from Al Ain airport on Monday and Tuesday to take advantage of convective cloud formations, according to Ahmed Habib, a specialist meteorologist. The NCM on Wednesday said the seeding had taken place on Sunday and Monday, and not on Tuesday. Cloud seeding involves implanting chemicals and tiny particles — often natural salts such as potassium chloride — into the atmosphere to coax more rain from clouds."
Peter.Bridge
1,866
828
“It’s also worth noting that forecasters, including the Global Flood Awareness System (Glofas) which is run by the European Commission as part of the Copernicus programme, were very accurately forecasting a high risk of floods across a wide area of the region a full week ago. Forecasting systems such as this use detailed observations of conditions in the sea, air and land, and combine them in forecast models to predict future flood events. If these models were predicting that floods were highly likely a week ago, it’s unlikely that humans could do much about it, other than prepare themselves to get out of the way.”
Reactions: flecc and Woosh
17,441
The amount of iodine dust that a small plane can spread is tiny compared to the amount of rainfall (some 250mm in 3 days, average annual rainfall 95mm) and on such a wide area. it does not matter much anyway if an experiment went wrong. It's not as if the seeds can multiply, we are talking about billions of tonnes of water falling on hundreds of squared km.
Reactions: Tony1951 and flecc
4,236
What's that got to do with it? The water is in the air. The seeding is like a catalyst. It only takes a small amount to make the water come out of the air.
Who said it was a small plane?
6,733
hope there not Boeing planes as might start raining doors and rolls Royce jet engines :p
why dont we just blow up the moon? what could possibly go wrong :p
