Hi,
I have a Milan which I purchased September, 2006, and it has had very little use, I have probably only done about 50 miles in total.
The problem I have with it is that the last time I used it the drive ceased to work, even though the motor was turning as normal.
I have contacted the supplier, Powerscoots, for advice, and they have failed to respond in any way.
I have since ascertained that the fault was on the planetary gearing, one of which seized and as a consequence stripped the teeth off the three planetary gears.
My problem is that none of the suppliers of PowaCycles that I have contacted have replied to my request for information regarding spares.
It appears that once you have parted with your money you are on your own.
I also discovered that Powacycle was part of a larger group of companies called Akhter and I was going to write them to see if they could stir their company into action, but they are now inaccessible.
Any ideas or suggestions.
