Hello I found your forum after googling about battery issues on my mrs ebike.
We bought it used last year very cheap, it was sold because it cuts out occasionally on hills. My Mrs used it a few times but it only cut out once or twice as she is a bit lighter than the bloke we bought it off. It didn't really get used after October and I charged it a couple of times in between as the manual recommends that it be charged at least every 3 months.
After trying to use it the other day the red lights on top of the battery pack cut off pretty much after the first acceleration and you have to turn the key on and off to make it go again.
I charged the battery back up this morning and measured the voltage at the terminals at the bottom of the pack at 41.8v.
I stripped the pack down at it consists of 30 22650 cells 2500mah hour. I tested individual groups and found most were sitting at 4.19v except the top row of 3 closest to the bms which was 4.14v and the next row of 3 which were at 4.06v. Is it OK to manually charge them rows like this with my multi charger?
Would the pack being out of balance like this potentially cause this issue?
