Hi All,
I have a 10S4P battery arrangement, each cell was charged and tested, and measurement of each cell was between 4.1v to 4.2v when done. I built the pack up and measured 41.5v across the output.
I bought one of these BMS:
All wired correctly and double checked the balance wires. All appears ok.
Problem is, when the battery needs a charge, it appears to only charge to 38.5v volts. The external charger 42v,2A is red and turns green when the voltage of reaches 38.5v.
Any ideas why it's not reaching a little closer to 42v?
10S 36V 30A Li-ion Cell 18650, GPS Accessories TMC Module Receivers Battery Protection BMS PCB Board With Balance Function Overcharge Over-discharge Over-current Protection : Amazon.co.uk: Electronics & Photo
www.amazon.co.uk
