Well, after much deliberation I have entered the realms of electric bike owners. The bike is a Dahon Caio conversion from CH White. So far first impressions are favourable. Although not as powerful as some mentioned on this forum - 180 watts, it got me to work and back yesterday, about 6 miles each way by the direct route with a few smallish hills, with no problem and pretty quickly too.
A couple of criticisms concern the weight which at 18kgs without battery make it too heavy to be heaving in and out of the back of the car on a frequent basis. I take Fleccs comments on lithium batteries, but a smaller, lighter battery that could use the standard rack would make all the difference to portabilty.
The twistgrip throttle, although easy to use, is a little small in relation to the handlebar grip and could be tricky if you have a poor grip. Even though I have a decent grip, I may need to modify this. Removal of the front wheel also looks daunting and could do with some way of allowing the motor wiring to be disconnected easily. I suspect that this may be common to a more than a few ebikes.
The Caio may look a little strange but is a joy to ride. More comfortable that my other folder - a Trek F600, which feels very harsh in comparison. The 5 speed hub gears also seem well suited to electric power.
On balance I'm quite pleased - especially with quality of the Dahon. The service from CH White has been very efficient and the fact that they are a well-established firm was the main reason I bought from them instead of one of the cheaper ebay bikes. May have a go a writing a review when I have had more use of the bike.
