Please help: What LCD Display is compatible?
florians
Aug 8, 2022
Hello folks,
you are my last hope.
I landed in the river with my bike (luckily both me and the bike were unharmed), but the LCD display is gone.
It was this display:
https://drive.google.com/file/d/1tLh_erPaKaq1b-PbUKBSFzD8xkErGjql/view
(with the water proof, round, green plug)
48452
The motor seems to be a BAFANG Hub motor with 250W, the controller seems to be a LSW1188, the batteries are 24v.
Can anyone help me find a compatible replacement LCD display?
Thank you and best regards
Florian
PS.: This here unfortunately didn't work (Error E10 - protocol error, maybe I need a display that supports CAN-BUS, not only UART?)
8,589
Tbh with lishui and intelligent stuff they are mainly oem, it is easier just to buy a new matched lcd and controller to replace both. Likely the controller will also be water damaged as ebikes don't swim very well.
Reactions: PC2017 and florians
florians
Aug 8, 2022
Thanks!
Basically a good tip, I think. But in my case I know that the controller still works. The e-bike is still running (with motor assistance), only the LCD display is gone. So it is still functional.
You may be right: I might have to try to find the exact same display again.
So far, I've only found it overpriced, and it's probably not very common on the market anymore.
So I was hoping to find a modern, compatible and at the same time cheaper device.
If anybody knows which displays might be compatible, I would still be gratefull
Benjahmin
2,598
1,755
70
West Wales
Generally speaking the only way to ensure a controller and display working together is to buy them as a matched pair.
It is possible that the bike manufacturer has some, unique to them, code programmed in that a newly bought display, even of the same make, wouldn't have.
Reactions: florians
8,589
I'm not 100% sure with Lishui but Woosh will have more in sight, The controllers and lcd's may still need programming as a pair to be comptible.
Reactions: florians
