Ping Battery Charger
chrisrenwick
11
Hi all, I have just purchased a 36v 20 A ping battery and the charger doesn't work?(no voltage coming out) I was wondering if any body could suggest a place where I could buy a reasonably priced alternative for this lifepo4 battery pack without damaging the battery.
aaannndddyyy
304
9
63
Norwich Norfolk
Have you checked the fuse in the plug and there is probablly a fuse in the charger as well.
Footie
549
10
Cornwall. PL27
If the lights are on, it would appear power is there, so fuse ok.
Is this the first charge?
My Ping battery arrived almost fully charged. I followed the instructions because it said the battery would need charging. I left it plugged in and turned on for 14 hours (just sat their doing nothing - red and green lights on ??).
Have you double-checked the wiring (just in case)?
Here's a link to a thread I did about replacing my SLA with a Ping battery (may be helpfully to you).
http://www.pedelecs.co.uk/forum/electric-bicycles/1741-dilemma-replacing-my-sla-batteries.html
If all else fails - have you considered emailing Ping to see if he can help identify the problem?
Li Ping - pingping227@hotmail.com
chrisrenwick
11
I have double checked the wiring, however I noticed that you had instructions with your battery, I did not - so I just connected the charger into a usa to uk adaptor wasn't sure which way round it went in as it fitted both ways. Then cut the terminal end off and connected the volt meter to the spare wires. Can you email me the instructions please.
chrisrenwick
11
Footie can you post the wiring diagram that Ian mentioned in your thread,
Chris
chrisrenwick
11
Is there a correct way to plug the charger into the mains- I have a usa to english adaptor and the plug seemed to go either way round. I wonder now if i could have damaged the charger plugging into the mains by getting the polarity wrong
john
531
Manchester
The charger can be plugged in either way around, it makes no difference.
Footie
549
10
Cornwall. PL27
If the re-wiring is correct (you've double-checked), the battery is uncharged (checked voltage or tested in bike) and the charger (when on and connected) shows red and green lights (red = power on & green = charged) then it sounds (to me) like, either the charger or the BMS is faulty.
Perhaps it's time to email Li Ping to see if he can help.
chrisrenwick
11
Just got a reply from Li Ping and he is posting a new charger to me and has sent instructions, thanks to everyone for your help- may need it again when the new charger arrives!:D
