Pelicase 1300 for a double stanchions(30mm) forks.
With metal support plate + 4 stanchion clamp (30mm) + cutoff switch (2 keys included)
Fully Rainproof. (using some silicon for cable outputs)
Google for more details and dimensions.
As an idea of the room I used to have 112 cells (18650) + 18 fet controller(without metal case) all packed inside.
Details:
Before buying make sure your stanchions are 30mm diameter.
There's a holes for all the cabling: Throttle, Phase, LCD display, even Horn and Lights. If you wouldn't need any of the holes just mask them with putty.
There's two rails inside to secure the battery. You can remove them.
Can be locked with padlock.
Bargain: 19gbp including courier. (pelicase itself was 30 and clamps were around 15gbp)
Details:
