PAS Wiring
danielrlee
1,394
723
Westbury, Wiltshire
torquetech.co.uk
Red - 5V
Green - Signal
Yellow - Ground
EDIT: I assume you are describing a pair of connectors (sensor & controller). If not, please ignore the above and provide further info.
8,533
Hi Help Brown5v- BlackGND- YellowSIGNAL - Red 5v Green? - Yellow? Thanks for any help John
I replied in another of your posts John, but now seeing this you must have another or new PAS sensor as wire colours have changed.
The KT controller is correct 5v Brown, Gnd Balck & Yellow SIg.
Your Pas should have a wire pin out say which is which, if no then as Daniel has said
5v Red, Gnd Yellow & Green Sig.
Brown to Red.
Black to Yellow.
Yellow to Green.
