PAS sensor question
morphix
2,163
119
Worcestershire
www.cyclecharge.org.uk
I noticed you can get these with 12 magnets in as opposed to the more common 5 magnet variety... BMS Battery claim the 12 magnets one makes the motor run more smoothly.
I just wondered if anyone has compared or thinks the 12 magnet one is significantly better?
Old_Dave
1,211
Dumfries & Galloway
5 magnets = 5 pulses per turn of the crank, 12 magnets = 12 pluses per turn of the crank
Thus.. (I recon, if the sensor is the same simple detector) the 12 magnets will trick the controller into giving a higher assistance per turn, which would be more noticeable at lower speed
But the magic words from BMS are
it can make motor run more smoothly .
"it can" means maybe ..lol
morphix
2,163
119
Worcestershire
Hehe. Thanks Dave. I think I'll get one just out of curiosity and do a comparison...will post up the results, but it may be quite some time ;-)
Not necessarily, it depends on the orientation of the magnets. Some have the magnet lying NS in the direction of rotation, so that as each magnet passes, the sensor sees a N and S in quick succession. Others have the magnets perpendiculat to the direction of rotation with alternate magnets orientated alternate directions so that the sensor sees a N and S with two magnets having to pass. I guess there's other possibilities too.
The KU series that BMSbattery sell give power according to the speed of crank rotation, so if they get a higher frequency of pulses, they give higher power at lower cadence. Maybe they wanted to lower the cadence for full power because the old algorithm was useless.
