Waiting to get the "proper" Lishui Controller out of Kudos (may be a long wait) I've put in a generic ("Brainpower") controller to be going on with. After sorting out connectors all is fine except that the PAS only works pedalling in reverse. I know the magnet disc is the right way round, it worked correctly with the old controller and hasn't been moved. It's a simple 3-wire sensor but I don't know what's inside. Presumably the controller responds to pulses of the correct polarity and I'm tempted to think that reversing the right two wires might sort this out. But which two? Signal and ground? Can I cause damage experimenting? Thanks, David.
PS - the other suspicious thing is that at the controller output, before connecting to the sensor, there is 5v between Black and Blue but only 4.3 Black and Red. Black is 0v. However swapping Red and Blue disables PAS altogether.
