PAS Sensor direction of rotation question
Bikes4two
1,032
444
Havant
  • As we all know the Pedal Assist System (PAS) sensor only produces an "I am pedalling" signal when pedalling forward but not when turning the cranks backwards (are there excptions to this?).
  • I am idley curious as to how the sensor works out the difference between forward and backwards crank rotation - anyone?
3,309
The sensor has a hall sensor in it, which will switch from off to on when the correctly orientated magnetic field passes it in the right direction. It will also switch the same when the opposite magnetic field passes it in the opposite direction. Wrong field direction or wrong movement direction won't switch it. A double hall sensor will only switch in one movement direction and one field direction.
matthewslack
2,019
1,444
The little chips we call 'hall sensors' have rather more inside them than just the sensing element, so they can be made sensitive to specific magnetic field changes.
