Hi all, I'm not new to building ebikes but I'm new to this forum
I have a XLD 866-18T 48v 1500w controller with s866 display and i cant get the PAS to work, I've tried all the settings on the display. my sensor is fine I've checked for voltage and spun it and its reading correctly I've even had the controller apart to double check the connection inside which is ZL on the board not uncommon on ebike controllers but no matter what I try the PAS wont work. This controller I believe also has a speed sensor with it which activates from a magnet on the wheel, I've also checked this for voltage and it triggers fine just in case this was actually linked to the PAS working correctly (although it would be the first one I've come across that does) Does anyone have any ideas.
