PAS Levels
I tried my LCD3 this weekend with my wattmeter attached and found the PAS amp levels a bit strange.
PAS levels 3,4,5 on s12s went something like 10a,14a and 26a, wheres the inbetween 14a and 26a?
I was expecting it to uniformly increase by a fifth.
Likewise on a s06s they went something like 7a,9a 17a with no inbetween 9a and 17a
Is this normal or have I a setting wrong in the LCD3 control ?
Its normal and you can't change it. You can switch the controller to speed control if you want so that the levels correspond to speeds rather than currents.
I will give it a go.
I guess the controller gives full amps until a particular speed is reached?
How are the 5 different speeds set ?
I can't find anything in the manual.
You can't set the speeds. They're pre-programmed like the currents. How much current you get depends on the algorithms in the programming. My guess is that you will get less current on the lower dpeed levels. You'll have to try it to see.
