- After 2 years being very satisfied with my TSDZ2 machines I am out of curiosity in the process of doing my first (front) hub conversion to see what ebike life is 'on the other side' of the argument (hub vs mid drive).
- So only some of the items are with me as I await the slow boat from China but I do have a PAS designed for mounting on the chainring side and is specifically for Hollowtech 2 type of chainsets (I actually have Campag power torque but they are of similar dimensions).
- This PAS is designed to mount to chainrings of around 22 teeth (74 PCD?) which is smaller than currently fitted (110 PCD) but I'll be making a 3d printed adapter to deal with that issue (hopefully).
- However, I'm aware that the Mahle X35 and Cytronex systems use a PAS that sits adjacent to the rear sprockets on a derailleur system and I'm wondering should my chainring PAS idea not work out, whether a sprocket PAS could work instead?
- QUESTIONS
- I've no idea what type of signal comes from the sprocket PAS and whether it is compatible with the PAS input on a standard KT sine wave controller
- and of course where you might buy a sprocket PAS sensor (that is, without selling body parts to get a Mahle part!)
The pics below are the PAS for Hollowtech 2 and the Sprocket PAS on a Cytronex bike.
