PAS compatibility KT controller
Dotingmule
Nov 27, 2024
I have the following kit - https://g-volt.shop/collections/conversion-kits-27-5/products/27-5-250w-e-bike-conversion-kit-road-legal
The PAS wasn't compatible with my bike so they supplied the alternative PAS - https://www.amazon.co.uk/freneci-KT-D12L-Sensor-Magnet-Electric/dp/B08JGZ3F59/ref=asc_df_B08JGZ3F59?mcid=99eecd00b0e3303186fd49e8a99b5d28&tag=googshopuk-21&linkCode=df0&hvadid=697258126966&hvpos=&hvnetw=g&hvrand=13383777928448552935&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9198634&hvtargid=pla-1693099436562&psc=1&gad_source=1
The PAS LED light is flashing when the pedals are turned but the motor isn't triggered. I have a KT LCD4 display which I have yet to connect but believe I can change the settings using the display. The controller currently has the display bypass fitted.
I think the PAS isn't working because I need to change the C1 settings. Please can you confirm the default KT controller C1 setting and what I need to change the C1 setting to for compatability with the KT D12L sensor.
Many thanks
4,226
Many thanks
Why do you guys always ask after you get the stuff and make the most problematic choices? Normally, 06 would be the correct setting. If it works only when you pedal backwards, change it to 01.
Those sensors are handed, so only work on one side of the bike. The "L" in the designation indicates left hand.
