The pronged connector is typical of the type used for battery discharge connections so you could replace both halves, soldering might be required.
Also you can get a Hailong version with 4 prongs.
Polly Battery case Power 5Pins discharge connector Male or Female [Polly 5pins Power connector] - $3.19 : Zen Cart!, The Art of E-commerce
Zen Cart! Polly Battery case Power 5Pins discharge connector Male or Female [Polly 5pins Power connector] - ★★★★★ Polly Battery case Power 5pins discharge connector Male or Female 1--5 pins is the male connector2--5 holes is the female connector 3--Use for Polly battery case ★★★★★ Contact...www.topbikekit.com
Thanks Neal,The pronged connector is typical of the type used for battery discharge connections so you could replace both halves, soldering might be required.
Thanks that looks great, I will see if I can get one, shame the original is so hard to get, considering motors that are replaced come with these, and the ones on the bikes are thrown awayHi Poker, this one should work.
Although it is 5 pin and you need 3 pins
Just make sure you put positive,negative and data connections in relation to your Battery.
Cheers,
bugsy.
