C
Cyclezee
I am setting up my recumbent trike and want to connect a 14Ah Li Po Ezee battery in parallel with the main battery to give extended range.
The Ezee battery normally sits on a contact plate, so I am thinking of buying an contact plate and wiring to make a parallel connection with the main battery and using a 32Ah MCB as an on/off isolating switch, then fitting these inside battery bag. I want to be able to remove the battery easily to use on my Forza, but at the same time have a secure connection with the contact plate.
As an alternative to buying a contact plate, I am also considering using 2 pins from a 13Ah domestic plug, these are the same dimensions as the poles on a contact plate, then custom making a 'plug' by moulding the pins in a block of visible light curing polymer or acrylic resin.
Has anyone done this before, or does someone have a better solution?
J hn
J hn
