Hi From New Zealand.
Apologies, its a bit long, short version is it does not go.
I've belatedly taken an interest in E bikes and was offered a non running Panasonic 'Hurryer' cheap so thought I'd have a play.
It was a locker find apparently and came with flat tyres, partially wrapped up, flat battery and no charger.
Appeared to have been in storage for some years.
Google shows its really a Japan only model although the motor I found thru this site appears in various Euro bikes.
I pumped up the tyres, oiled the chain, gave it a wash and it looks much better.
Rode it around the block and although heavier than a normal bike rides nicely.
Looking up batteries they seem to have moved on from the original 7 AH one and I can't find any locally.
Having trained as an electrician in the past I thought I'd see if I could get it going to see if worth preceeding.
Thanks to this site I was able to determine which was the pos and neg on the battery connector and hooked up two Shorai batteries I had from my motorcycles giving 26 volts.
Initially looked promicing as the display lit up, althought the three batter indicator LED's droped back to the minimum almost immediately.
The three speed modes selected and the headlight worked.
With my two batteries in a backpack I went for a test ride.
Nothing.
Tried on the flat and up an incline as I did not know what to expect.
I disassembled the battery and its laminar type with a temp sensor, 8 other wires that I assume are BMS wires, the negitive and fused (?) positive.
Also established that I had the right Pos and Neg connections on my temp set up.
Further reading here indicated that the third terminal on the bike is a battery monitor and that the motor wont run without it connected and having to use OEM batteries.
I've been around electronics enought to know that fiddling is not a great idea so wondering if anyone had found this and overcome it?
Before I spend up on a battery I'd like to know that the bike actually goes first.
Thanks in advance
John
Auckland
Nothing.
Thanks in advance
John
Auckland
