Pack Voltage
mygrumpy001
Hi All just made a battery pack 4x 11.1 volts wired series and parallel when i tested them it read just over 25v is that right or is their something wrong John
Alan Quay
2,351
1,076
Devon
Yes. If your packs are 3 x 3.7v (nominal 11.1v) then each pack will be 3 x 4.2v at full charge. Assuming you have wired 2s2p then you should expect 6 x 4.2v (25.2v) when fully charged.
mygrumpy001
Hi Alan thanks for the reply but I thought if you wire 4 11.1 in serial you get 44.4v the packs are 3s1p thanks for any reply
30,617
There must be a mistake in the wiring, since you should indeed get 44.4 v nominal (actual 50.4, much higher when fully charged) from 4 of those packs in series.
Your first post is a bit confusing since you said you wired 4 packs in series and parallel, so that 4 x 2 layout will only give 22.2 v nominal (but actually 25.2 v fully charged).
4 packs can only give the sum of the combined 4 voltages when in series, parallel pairs in series will only give the sum of 2 packs voltage.
Alan Quay
2,351
1,076
Devon
I think you need to post a diagram of how you have wired them. When you said 'series and parallel' I assumed you meant 2s2p, which would give you 22.2v
mygrumpy001
Is 50.4v to much for a 36v controller
30,617
Usually it's ok, since its capacitors are rated at least 50 volts and often more. Also that's only a quiescent 50.4 volts, under working load the voltage will be much lower.
mygrumpy001
R R
B TO R RR
B B
R B
R R
B TO R BB
B B
Will this do John
I think you need to post a diagram of how you have wired them. When you said 'series and parallel' I assumed you meant 2s2p, which would give you 22.2v[/QUOT
Alan Quay
2,351
1,076
Devon
You have wired the packs as 2s2p (so the cells are now 6s2p), which is why you are getting 25.2v
If you want 44.4v you need to wire all of them in series.
