Hi, has anyone retro fitted the optional throttle that comes with these ebikes? Some advice needed.
Thank you. I shall give it another go. Thanks both.Looks like there is a blanking plug on the connector. They are a tight fit, but hold both ends of the connector and pull firmly, it will come apart. Make sure you line up the arrows when you connect the throttle
