June 7, 20187 yr Hi i am going away next week and hoping to spend some time off road on my new bike. three questions 1. If deristrict it for off road will it void my warranty. 2. does anyone have the two digit code. 3. if I am off road and doing alot of small hilly sections is it best to get the throttle fitted, as I find it verry dificult getting into the correct gear Mick
June 7, 20187 yr 3. I don't know the answers to 1 and 2, sorry. I do, however, use my bike cross country a lot and the throttle is a big help there. Have fun.
June 7, 20187 yr Author 2. does anyone have the two digit code. you tube Ive tried you tube it tells you how to do it but not the current code
June 7, 20187 yr Author 3. I don't know the answers to 1 and 2, sorry. I do, however, use my bike cross country a lot and the throttle is a big help there. Have fun. Thanks Leigh
June 7, 20187 yr Author I have been in touch with Oxygen and they say it does invalid date your warranty so they don’t give it out, but I can find it on this Pedelecs forum.
June 7, 20187 yr Regarding the gear selection issue, I find that using the front chainrings more often off road helps me. I very rarely use anything other than the big ring on the road, but do drop down to the smaller rings when off road. It means keeping the front derailleur clean and oiled, but it's nice to have the option ready.
June 7, 20187 yr Author Sounds good, found that if I was in the wrong gear the bike would stop and be imposible to start again on a hill
June 7, 20187 yr Sounds good, found that if I was in the wrong gear the bike would stop and be imposible to start again on a hill You could try learning to use the gears properly...
