Just had a small problem with my Oxygen ST Cross, which I think is caused by a design fault. All through last year from April onwards I was able to ride without getting wet . Late on in year got caught out in heavy rain and was then not able to get out for a while. On using bike again I found that the rear brake cable was very stiff and would hardly work. However I dismissed it and thought nothing more of it. Decided to get out over xmas and found that the rear cable was virtually seized up. Replaced the cable and found it to be rusted. Now works but not smooth in operation. Must need a new outer. I think the problem has been caused because where the cable exits to go into the caliper it is pointing upwards and that water has run down into it. The fact that I did not use it allowed it to rust. Wonder if anyone else has had a similar problem. I will try and post a photo when I can figure it out on this damn chromebook
