Hi its the OXYGEN S-Cross ST 36V 13aHIs this the Oxygen 24" step through? If so, I have the same bike and it uses a silverfish battery, readily available from eBay and possibly more economic than a rebuild.
Can't you buy one from Oxygen? It should be a lot cheaper than a rebuild.Hi its the OXYGEN S-Cross ST 36V 13aH
....v expensiveCan't you buy one from Oxygen? It should be a lot cheaper than a rebuild.
thanks will take a lookdont these use a generic style retention battery the same or similar to this available at yosepower, aliexpress, ebay etc for half the price that Oxygen seel them for
36V 13Ah Lithium-ion E-Bike Battery Electric Bicycle for NCM Pedelec w
Power your NCM Pedelec with our reliable 36V 13Ah Lithium-ion E-Bike Battery, ensuring extended rides with dependable performance.yosepower.com
thanks very helpfulI have a mark 1 Oxygen ST which developed the same battery problem as yours- would only charge to 37/38v.
Sent the battery off to Torqu-e-cycles at 139 Babbacombe Rd, Torquay TQ1 3SR , see website.
No rebuild needed, BMS at fault. BMS repaired and battery charging to 42.8v. Great result.
Lot cheaper than battery rebuild - worth a call.
