Hi Easyman,
Thanks for your very comprehensive review, much appreciate your comments incl those negative ones and will certainly take these on board.
Now coming to your problem of speed reading. Please press SET for 3 seconds to enter settings mode, then quickly press SET again 4 times so the left bottom figure changes from mode 0 to no4.Then In your top right corner you will see digit 6, with + or - button change this from 6 to 1. There are only two options in mode 4, its either 6 or 1, must be 1. Do nothing for 3 seconds and this will exit settings mode automatically, your sppedo will now show correct reading. Please make sure you do everything quickly, if you do nothing for 3 seconds it exits settings mode automatically.
Any problem with this just give me a buzz on 0773 8866502, will guide you then over the phone.
All the best
Andrew
