Reviewer : Rob Walley
Purchased From : 50Cycles
Purchase Price : £799 + fitting
Time Owned : 1 month
Local Terrain : Flattish, South Bucks/Windsor area
Background : Owned Kalkhoff Pro Connect 2009 model for nearly 4 years. Very happy with performance but never liked the dutch style look. Also older model which only goes up to 1.3 times assistance and had the nexus hub which I replaced with a alfine when I found one cheap. Sold this recently and bought Cube Hooper Pro 11 speed Alfine which seems like an excellent lightweight low maintenance choice for the oxydrive kit. Most cycling is short commute to work and family cycling, unfortunately with emphysema I need electricity to get up hills and keep up with kids.
Strengths : Great performance across 5 levels of assistance on the flat and hills, throttle for those really lazy arrogant moments. Every useful piece of info on an LCD display. Easy software setting to change max speed up to 30kmh(not really). Total additional weight around 6.5kg. Very good design – doesn’t ruin the bikes look. Good balance of weight distribution (with Alfine anyway).
Seemed to take one bar in five in terms of battery life for the first 12 miles although only on level one assist, a good start.
Weaknesses : Expensive, tricky to fit (my bike anyway), a couple of design flaws. 50Cycles fitting.
Summary : Not being mechanical I paid 50cycles, what I think is good money to have this fitted to my Cube. Unfortunately this was not done at all well and I have re-done everything from scratch including a wheel build. In summary the wheel was not aligned, the cabling was done incorrectly and the pedal sensor disc was fitted so badly it was tilted and rubbed on the receiver sensor, this was confirmed by Andrew at Oxygen.
The main job to be done was fitting a longer 127mm bottom bracket instead of the 118mm 50cycles fitted, this was too short for the sensor as it had to fitted mirror image because of the compression fitting bolts of the eccentric bracket being in the way, for future reference horizontal dropouts must be a better method for hub gears.
I am also a little fussy, so rebuilt the motor into the orignal Alex rim, bought 2 matching disc rotors with an centre lock adapter for the Alfine and re-routed all the cabling for a neater less cluttered look, clearly mentioned in the oxydrive manual.
Ignoring all these minor niggles, the design and performance of the oxydrive is excellent and I have the added bonus of being now reasonably knowledgeable about bicycles and have a couple of extra tools for future fiddling.
2 small flaws I have pointed out to Oxygen; the cable to the wheel motor is hard wired and really should be a L shaped plug at the hub, makes it impossible to take the front wheel off without cutting cable ties. Andrew at Oxygen has already thought of this and assures me the next batch includes this improvement, not always good to be first I guess. The second is really software and although Andrew thinks it’s a good idea, might be a little more tricky. Because the LCD display is an all in one unit which has speed and odometer, when the assist is off, so are these functions, as well as 1-5 assistance, I suggested a 0 level for no assistance, but maintaining power for the display.
This is an early review, more in a month or so.
Overall Rating (out of 10) : 8 – hopefully 9 later.
