need skilled assistance please..... I bought 3 years since a new pair of Orbea GAIN 250w rear hubmotored wheel and as a mate was running a gain we fitted and found it was working as per usual. so long story short bought a Whyte frameset RN7 and a TdZ motor and custom built battery found that RN7 2020 framsets those with internal cabling the bracket shell is barrelled so neither TDZ or BAFANG would fit through their various upstands and bolt upstands fouling on this swollen ridge on the bracket shell, so i pulled the wheel set down and a competent electican friend said why don't we fit the hub motor wheel and see if we can get it to operate with a stand alone controller, you have the 36v battery.. thats where we are ,he has it running on a test rig , however his findings are that it doesn't like modern control so he says, we have it on video at 17.5 mph on the bench but it would need more than that on a test road.. he has now undone the outer casing on the loom which connects the hub to whatever controller hes using , i gave him a couple of Bafang ones i had been supplied by my source in UK..he wants to test and trace all values of these 9 wires so he can isolate whatever is controlling or governing the wheel speed.. any ideas chaps .thanks . i 'm all ears
