This problem is driving me nuts! It’s a Chinese e-bike with the battery inside the down tube. If I take the front forks off to access the battery, I can pull it out a bit wait 10 seconds, reconnect and all is good. Bike switches on and everything works as should.
The problem is that when I turn the bike off or it auto shuts off (After 10 minutes) it will not come back on unless the battery is disconnected again. It’s definitely not the battery as when it’s working I get the max mileage out of it. The bike is a Kakuka k70. Any help would be so appreciated.
