Eventually got the new (Brainpower) controller shoehorned into this very old Giant Twist Express. Fitted a PAS to the crank, as the torque sensor on the rear dropout needs a bit of voltage shifting/remapping to work with the throttle input, and I can't be bothered to do anything until such time as I think the bike's viable. Everything works OK, except that it really struggles to get my 185lbs up the nearest hill. Which is a shame, because the only reason I acquired it is that I'd like to get some cycling in for exercise, having had a triple CABG a couple of years ago, but live in a very hilly area. The batteries are only 24V, but I tested them with a 24v 100w light bulb, and they both seem to have about 80% of the rated 9Ah capacity. The display(S866) shows in excess of 300w at times, although there is a bit of voltage droop(that's normal, isn't it?).
Would it be worth me trying a 36V battery, or would I fry the motor?
