I have been somewhat bored lately. Then I realised that I have three grandsons, none of whom had a bike. So I started having a scrounge around for some cheap or free bikes that I could repair and pass on. The first on was a mountain bike, bought off facebook for a fiver. The rear wheel was so buckled it would not rotate in the frame. three spokes were broke, all on the cassette side of the wheel. I removed the cassette, and fitted three spokes from a wheel I found on a cycle path.It is now reassembled, and being used.
Bike number two was a gimme from a guy up the street, as he has bought a new one. It needed a clean,lube job, and a puncture repair. It is now up and running.
Number three was also a gimme. Owner bought a new one, and reports that the problem was gear slip. I found that by using all my strength, I could cause the chain to slip. At first, I thought it needed a new cassette and chain. It would only slip under hard acceleration. Then I noticed that the chain was actually slipping on the Front Chainwheel. Examination revealed that the middle chainwheel teeth were more worn than the other two chainwheels.
I had another bike in the shed that has been scrapped due to worn rear wheel bearings. I took the cranks and chainwheels off that one, [they looked good] and fitted them to bike three. Al;though I could not make it slip, my son in law, who is young and fit, tried it and said that with him, it slips enough to be a nuisance. I then changed the chain to the one off the scrap bike, reasoning that that chain, and the "new" chainwheels had previously been run together without problems. Son in law can still make it slip. Both chains look serviceable when measured for wear with a ruler.
I am running out of things to check. Rear derailleur is a bit battered, but changes reliably. There is some wear on the rear cassette, but that would not cause chain slip at the front chainwheel. The rear derailleur is good on the scrap bike, so I might swap it. The only thing I can think of is the chain tension adjustment on the rear derailleur.
The question is, has anyone had this problem before, and how was it solved?
