Problem now is I factory reset it and it updated. Now I cant download any maps because I cant connect to Wi-Fi any longer.
I had this problem once , contacted Bosch via facebook and was given this reply "if you can not activate the WLAN at the Nyon after the update, please get in touch with your local dealer. He should use a Bosch diagnostic software to perform a so-called flash update with your nyon"
My dealer initially had difficulty in getting the diagnostic software to run. I cant remember the exact details but think he fitted an Intuvia, this allowed something to be reset on the DU. A DU forced flash to the latest firmware was then carried out. The Nyon was refitted and its firmware reflashed.
That cured the problem, I assume that there must have been some compatibility issues between the DU and Nyon firmwares as the DU firmware had never been updated prior to this.
Hope this is of some help, looks as if you may have to visit a dealer with the bosch diagnostic kit.
My nyon is on 2.7.5.0 [front & back-end]. The DU software is on 1.8.0.0, hardware 0.0.6.0
From the Bosch website the latest versions for Nyon are 2.7.5.0 and 1.8.3.0 for the DU
