May 22, 200718 yr Can anyone please advise on these batteries One Long NiMH 12V 10000mAh (120Wh) Battery Module - NIMH-12V-D10000L Are they a good price? Could you use 2 for recelling / creating an additional battery? John
May 22, 200718 yr It's a rather misleading advert John, the description calls it a 12V 10Ah pack, yet says "Made with 10 x D 5000mAh TENERGY high capacity NiMH Batteries assembled side by side" which is only 5Ah, the lower figure being reinforced by the quote "Delivery 8 - 9 hours of run time with typical emergence light (500mA discahrge current)" which equates to 4-4½ Ah. $90 for 10 5Ah cells is not particularly good value, especially with shipping charges on a heavy item from the USA and the possibility of import duty. The powacycle 24V NiMh battery represents better value, and 50cycles are once again advertising their 36V NiMh batteries at £170, albeit with limited availability.
