Newbie needs advice on e-bike for heavy person.
Cabourn
May 14, 2020
I want to commute to work (16 mile round trip) on an ebike if possible. I have a big problem in that I weigh 120kg (approx 19 stone). I have a £2500 budget for a new ebike and I need recommendations on which bikes I should be looking at. I want an hybrid bike with a normal frame (not stepthrough) which will take my weight and the commute is on main roads with no steep hills.
Many thanks in advance
Croxden
2,134
1,384
North Staffs
cyclebuddy
1,632
769
Beds & Norfolk
I doubt that's really a problem. I weighed more than that when I started e-biking on a standard "nothing special" 700c wheeled hybrid ebike. You just need to be aware you are over the usual 100kg most makers recommend, and take care not to over-stress the motor or bike in general, use the gears properly to keep your cadence up and not just "ghost pedal" so the motor is forced to do all the work. Both my hybrid bikes (both £1000ish lower-end crank drive) would and still do climb a 15% hill.
The only issues I really had was tyres; most 700c road tyres on hybrid/commuter bikes are only rated to about 100kg... I blew out the side-walls on two (over 1500 miles) for no obvious reason!
Yes, Woosh's Big-Bear is a pragmatic solution, but I'd also look at some of the £2k Cube hybrids given your fairly generous budget, and put some puncture-proof Marathon Plus tyres on it for road commuting.
Reactions: Cabourn
