Hi all
I've been lurking for a while, and now have the important approval from the financial controller (aka she who snores in my bed) for buying a kit.
I'm more or less settled on the BMSbattery 500WCST kit, built into a 700C wheel for my Surly Cross Check. Thanks to D8veh for the helpful advice.
However, I'm realising there are lots of things I don't know!
I'm hoping to use 2 batteries (probably 36V 12 or 15 Ah) to balance weight, either in 2 panniers on low riders by the front wheel (as I usually have at least 1 pannier on the back anyway), or in rack top bags at front and rear. Which option would you recommend?
Secondly, when wiring 2 batteries in parallel, do I need to do anything clever on the wiring? I vaguely remember seeing mention of diodes to stop one battery trying to charge the other one if one flattens faster than the other but now can't find mention of it!
Also when charging twin batteries can you charge both in parallel off a single charger (so I can leave one at work and other at home)?
I'm sure I'll think of more questions later...
Phil
Phil
