I've just put the cyclotricity kit on my Trek 7300 hybrid. Fairly straight forward apart from a few nervous moments with an angle grinder and the forks and a few curses about the position of the bottle mounting points on the trek.
When setting up the dashboard I seem to have found a menu not documented in the manual. It appears on pressing the up and down buttons at the same time when already in set up. The bottom line then cycles through something like ... P1 88, P2 1, P3 1, P4 0, and P5 12.
What do these settings mean and does anyone know the default (I may have changed some of the parameters trying to get out of this.
I don't have the controller details easily to hand. Fitting it into the box was not easy and its well secured now with tape and cable ties!! The dashboard is a KT_LCD_V2.5 (Suzhou Kunteng Electronics.
All advice and help gratefully received
Keith
Keith
